26-03-2017, 05:37 PM
Yesterday I started up my 1974 Lister air cooled marine engine. I was a bit nervous as it hadn't been started since September due to very bad weather. Fortunately it started easily enough. Last year I had to replace the alternator so used a Lucas which is OK although it needs a tighter belt. Yesterday I put a small bulb from D+ to battery + in order to energise the alternator (it had to rev a bit for the light to go out). Everything was hot-wired as I haven't redone the panel electrics yet.
At any rate, vintage boat electrics go back to an era when electrics were simpler with less gadgetery. Typical layout would be:
(1) Split charge relay with two domestic batteries.
(2) Ammeter and shunt plus voltmeter.
(3) Panel with switches for lights, pumps, navigation lights and radio et cetera.
(4) Back up solar or wind charging system.
(5) Shoreline hook up for onboard AC.
Good site on boat electrics is
- www.fishingandboats.com
