23-03-2017, 04:45 PM
That cheered me up as I thought I'd failed. The pump at first failed to prime. At that point I was disappointed. Then I tried putting the suction hose to a regular tap and got some water in it. After that I had one ice cream tub of water and a big paint tin and powered the pump. After that it pumped. Prior to that I used silicon on all gaskets but found torquing up the bolts tricky. Now I just have to hope no leaks return as the idea here is to save myself 90 quid on a new pump.
The next stage is to make a water tank and make a pipe insert for pump connection. I already have lots of plastic pipe because people chuck that away as well as old pumps. The sink unit I built last year after 5 attempts but the door was discarded by joiners so I hinged it on. I may use electric to heat water and not gas.
Basically I have to finish and be moved on this boat by August and the plan is to use wind and solar so I'm independent. All my radio work will be squeezed in between.
