10-11-2016, 10:22 AM
(This post was last modified: 10-11-2016, 10:27 AM by Old Sparky.)
I'm in the middle of returning one of these in-car record players to working order - this one being made around 1970 as it has the electronically governed motor as fitted to the latedr 22GA101. Basically it's working, although I'm hoping to be able to replace the missing stylus brush/lever assembly, pilot lamp and rubber 'flap'. However although the autostop trips at the end of a record, the disc isn't ejected automatically as it should be, despite my having cleaned/relubed the autostop mechanism. I have a full service manual for this 'ancient' bit of I.C.E., and ahave several times serviced them in the fairly recent past. but, despite that, cannot figure out why the records (7" 45s with the latrge centre hole for those unfamiliar with the 'Auto Mignon' as these are called) don't automatically eject. If I operate the machine without a disc inserted, the eject mechanism works OK, which suggests that the disc is fouling something, but I can't for the life of me see what. The 'centering disc', a spring loaded device which goes into the centre hole of the record to hold it in place on the turntable whilst playing, appears to work as it should. Too much friction here would obviously stop the record from being released.
Does anyone have any suggestions as to what may be the cause of this fault? BTW, I think this is worth trying to repair/restore, as there is one in tatty condition on U.S. eBay on a 'Buy it Now' of almost £200 at the moment!!
