10-04-2016, 08:48 AM
I have successfully made many audio CDs from continuous files, using cue sheets, with the following format:
REM Created by CueListTool
TITLE "CD Title"
FILE "Audio file name" WAVE
TRACK 01 AUDIO
TITLE "Track 1 title"
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE "Track 2 title"
INDEX 00 mm:ss:ff
INDEX 01 mm:ss:ff
TRACK 03 AUDIO
TITLE "Track 3 title"
INDEX 00 mm:ss:ff
INDEX 01 mm:ss:ff
I usually set the index 00 marks to give 3 seconds negative countdown time to the start of each track.
I'm using Windows XP Pro with SP3 and have these optical drives, an LG HL-DT-ST-DVD-RAM GH22lp20 2.00 and a Lite-On CD-RW SOHR-5239V 2$0A. The mother board is a Gigabyte P4 Titan 533, GA-8IHXP, with the Intel 850E chipset - yes, it's very old!
Until recently, all index marks (including ones higher numbered than 01) were written to the disc and, after extracting the audio from the disc, in Audition 1.5, they could be seen in the waveform. Now, however, only index 1 is being written to the disc. Extracting the audio from a disc with all the above index marks, results in only index 1 being recovered. When saving audio files in Audition, 'Save extra non-audio information' is checked.
I have tried a number of different CD burning software applications, such as CDRWin, ImgBurn, Ashampoo Studio and Feurio, with no difference.
Feurio did complain that there were different ASPI versions, so I downloaded aspi32-fixXP.exe (version not available) 105 KB, aspi32.exe v1.0.2.14 281 KB, and aspichk.exe 1.0.0.6 112 KB, as found on this web site: http://home.werner.no/lars/aspi
After installing those files, running aspichk.exe gave these results:
LOG0144: Starting ASPICHK installer on Tue Mar 22 16:45:51 2016
ASPICHK0438: OS = Windows NT (5.01.2600)
UPGRADE1004: c:\windows\system32\wnaspi32.dll dated 09/10/1999 12:06:00, 45056 bytes.
UPGRADE1062: c:\windows\system32\wnaspi32.dll version 4.6.0.1021
UPGRADE1004: c:\windows\system\winaspi.dll dated 09/10/1999 12:06:00, 5600 bytes.
UPGRADE1062: c:\windows\system\winaspi.dll version 4.6.0.1021
UPGRADE1004: c:\windows\system32\drivers\aspi32.sys dated 09/10/1999 12:06:00, 25244 bytes.
UPGRADE1062: c:\windows\system32\drivers\aspi32.sys version 4.6.0.1021
UPGRADE1004: c:\windows\system\wowpost.exe dated 09/10/1999 12:06:00, 4672 bytes.
UPGRADE1062: c:\windows\system\wowpost.exe version 4.6.0.1021
ASPICHK0582: ASPI is properly installed and is fully operational. A total of 3 host adapters have been detected.
LOG0218: Closing installer log on Tue Mar 22 16:45:51 2016
As far as I can tell, all settings appear to be correct.
Does anyone have any idea what could be causing this problem? Thanks.
Regards,
Dave.
TITLE "CD Title"
TRACK 01 AUDIO
INDEX 01 00:00:00
TRACK 02 AUDIO
INDEX 00 mm:ss:ff
INDEX 01 mm:ss:ff
TRACK 03 AUDIO
INDEX 00 mm:ss:ff
INDEX 01 mm:ss:ff
Regards,
Dave.
