17-03-2016, 09:07 AM
I couldn't get my iphone to charge this morning and tried several cables/wall-warts with no luck. Then I remembered a similar problem with a Brahma lock we have on our front door! The special key has a hole in its centre which locates on a pin in the lock and normally it works very well. It then stopped working and I eventually traced it to "pocket fluff" which had accumulated in the hole in the key which prevented it fully entering the lock. A crochet hook or similar hooked out a huge amount of compressed fluff after which it worked perfectly. A lead from a capacitor carefully inserted into the connector on the phone resulted in a similar harvest! The phone charges again so if you have a similar problem, out with a capacitor!
Cheers
Brian
My wide-band IF problems are no more - now I've got others!
Brian
. But If I'm going past Brahma I will call in for a look and a chat.
