06-03-2016, 11:53 PM
Hello,
Over on UKVRRR, a recent discussion about DVM voltage references coincided with some investigation work that I'd been doing, and I've finally found a bit of time to finish the project and document it.
That thread contained plenty of discussion that I don't need to repeat here, so I'll launch straight into an overview of my design:
The core idea was to combine a number of cheaper voltage references to get a better overall accuracy. It's well-known that combining passive components in series or parallel results in better accuracy, but the same argument should also apply to voltage references. To see if that was the case, I spent a few days measuring 60(!) of them, and went ever so slightly mad in the process. However, it works
The ICs in question are the "good but cheap" LM4040. The D-grade parts are rated to 1%, but in practice most samples proved to be better than 0.5% (which matched my expectations, based on my previous experience of them). The more expensive A-grade parts are specified to 0.1%, but I did find that not all of them met this spec, which was a surprise. More sampling and investigation required.
Anyway, four 2.5V 0.1% references in series reliably gives 10V at 0.05%. No selection or adjustment is needed, beyond checking that your samples meet the 0.1% spec.
Having done that, you also have 2.5V, 5V and 7.5V available. And while you're at it, why not add a 5th option for 12.5V? And a divide-by-10 option doubles the output options to 0.25V, 0.5V, 0.75V, 1V and 1.25V.
Finally, add a low-battery indicator and output protection (the latter always seems to be missing from the DIY and Chinese offerings). An afternoon with a drill and a basic die-cast enclosure completes the package.
So, a little bit different to the norm, but good results for not much cash. Not that it can compete on price with the cheapest Chinese offerings, but at least I've had the fun of building it myself, and I hope it gives people some ideas for their own projects
Lots more detail is available here: http://www.markhennessy.co.uk/dvm_reference/
Hope this is of interest,
Mark
Mark
) - it's based on Morgan Jones' write-up in the latest (4th) edition of "Valve Amplifiers".
