05-11-2015, 09:05 AM
To clarify; There is no sound from any of the 6 channels on this Home cinema amplifier when a signal is applied to the analogue audio i/ps, either from an audio sig. gen. or from my MP3 player. The following symptoms have been observed;
1) When powered up & switched on, the centre rail voltage at any of the 6 speakers rises to ca. 7.63vDC over about 20 seconds and is then stable
2) The unit powers down after about 3.2 minutes with no signal i/p,with little or no switch off thump, but if swiched off via the on/standby button or at the mains a considerable thump is heard in the buit in wooffer. The Thump is at the same level regardless of the volume control setting.
3) Current consumption appears to be normal at around 60-70mA quiescent.
4) According to the display, the function switch is working, but a quick perusal of the block diagram suggests that the fault is in either the electronic switching or preamplifier circuits.
Does anyone 'out there' have any experience of this model, and have any idea as to what may be the cause of the faullt and whther it is repairable? No-one appears to stock any specialist spares for these amplifiers.
