29-09-2015, 01:11 PM
No, I didn't get a cat.
For some years I've used an Evoluent vertical mouse. This almost completely solved an RSI problem I was suffering at the time. It's like an ordinary mouse but turned through j (90 degrees to those who aren't conversant with complex numbers, or i if you're a mathematician rather than an engineer) The idea is that your hand is in the natural "handshake" position rather than having to twist your wrist. Highly recommended and well worth it though not exactly cheap, about £60. Takes a little getting used to and definitely not usable if you're left handed. (LH version available too).
Over the last year or so I've been getting increasingly annoyed with the scroll wheel which has been intermittent and getting worse. Today I took a closer look and found that the rubber tyre was slipping on the plastic wheel. I pulled back the tyre and put a small drop of contact adhesive in the gap. It's fine now.
