28-09-2015, 03:14 PM
McMichael Twin Supervox 20 years in repair…
In the Fall of 1995 my Italian friend sent me a McMichael Twin Supervox. I hit problems in acquiring documentation and encountered some restoration issues I was not equipped to address properly. So… It has sat in silence till this very rainy week. It is now on the bench in pieces. I’m confident the conservation and restoration can be completed. I do however need some bits of information that I hope some of you can provide.
This radio is certainly scarce on this side of the Atlantic. But very interesting to me in that it shows the first attempts to make metal shell valves (Catkins) and has the Metal H.T. rectifier never used in the USA. I think my set is truly worthy of restoration so that I can exhibit it here at various conferences. So answers to this query would be greatly appreciated.
Yours,
Robert
- I presume that there was some sort of safety cover on the back of the cabinet. I have not found a photo of this on the Web. Any photos of this cover would be greatly appreciated so that I can fabricate a credible replica.
- It is obvious that some sloppy repairs were done on the set. The Trader Service Sheet #557 Rev. 4 shows the Westinghouse Metal Rectifier mounted under the speaker… In my set the MR is precariously perched as shown in the picture and a 8 ufd. dry electrolytic is laying loose in the bottom of the chassis. (I presume this is a replacement of C23.) Are there any photos that show the correct arrangement of the rectifier and C23? How is C23 mounted?
- Our sloppy repairman seems to have misjudged clearances and found he could not replace the chassis side bracket after doing his dirty work. It seems to me that this bracket is virtually identical to the other bracket except for the mounting of a small phenolic (?) board. Are they the same?
- The loudspeaker grill cloth in my cabinet is completely wrong. The Web pictures I’ve found don’t have enough resolution to show the pattern weave… I need better snapshots.
Yours,
Robert
