24-09-2015, 04:10 PM
A few observations on American circuits. I have taken a pic of a Cathode follower from my American HAM theory book as it had me puzzled. I thought I would take a photo from the page of my book and see if it would upload. It seems that it has uploaded. I always find I can upload the first pic I take with my digital camera.
Here is what had me baffled: If you study the pic of the cathode follower doesn't it seem to you that the signal is incoming between cathode and grid? Apparently not. It states the signal is between the anode and the grid. It adds that there will be some negligible impedance in the batteries.
After trying to sort all of this out, I finally concluded that the big factor here is that, in the cathode-follower circuit, you can see a resistor between cathode and ground, yet there is no resistor directly between anode and ground. In most other circuits I've looked at there is always an anode resistor similar to the other illustration above.
Thus, it seems to me the cathode follower in this diagram allows the signal to bypass the cathode due to the cathode resistor (I can't recall its value) and it passes to the anode instead. Finally it seems the AF is built across R in the lower illustration. I'll go over it again tonight maybe.
In any case, I find a few differences in American circuits. One thing you notice is they have a tendency to use grid bias batteries. This may be the case with output tubes. I've seen American circuits where a battery is used to create a fixed cut-off bias. Not sure why they didn't always just use a GB resistor.
Or B+ in US speak.
