19-08-2015, 11:44 AM
This battery-operated design by Ian Liston-Smith, G4JQT, uses the headphone output of any portable audio player to generate an AM signal for reception on a nearby medium wave radio. It has a range of just a few feet so there is little or no risk of radiating a signal beyond the room in which it is in use. Ian's design criteria was that it should have high quality sound; be simple to construct and put into use; would accept headphone audio feed from MP3 players, CD players etc; would be battery operated, and would be reproducible. It certainly fulfils those criteria.
The design featured in the Winter 2011 BVWS Bulletin since which time it has generated quite a lot of interest, and quite a lot seem to have been built. It uses two 90uH 'Toko' style cored coils, cheaply available from Spectrum Communications. Some constructors have built the Mini-Mod on strip-board - others on printed circuit boards, for which Ian has kindly provided a layout as shown in the second pic below. I used the same basic component layout as Ian's, but adapted the tracks to give a little more clearance between the tracks and the ground plane so as to make it easier for me to etch on a DIY basis, and to minimise the risk of 'bridges'.
Initially I had problems in getting it working, which stemmed from the BF256 FET I'd used having different pin-outs from the data. Among my collection of BF256s I found some which had the pin-outs marked, and this confirmed that pin-outs don't always correspond to data sheets, as shown from the pic of the transistor below, where the pinouts marked on the BF256, they don't correspond with the datasheet in that the drain and gate are the opposite way round, with the source still in the centre, but luckily, they're marked on that particular transistor. (I'd tested the FETs on my cheapo Chinese 'multi-tester', but it gave ambiguous results). When I changed the drain and gate leads over, the Mini-Mod worked fine.
I've attached a pic of Ian's circuit, his PCB layout, the one that I designed based along the lines of Ian's, the completed PCB, and in the last pic, the Mini-Mod boxed up in it's 'wooden overcoat', which measures 11.5cms x 8.5 cms x 6 cms (approx. 4.5" x 3.5" x 2.25"). I've since built a second one, which worked straight off with no problems. I have it close to my Ekco A22 with about a Metre of flex draped on the floor as an antenna.
Full marks to Ian for conceiving this neat little circuit!
Hope that's of interest.
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
