09-08-2015, 07:46 PM
I've had a Kindle Paperwhite for two or three years, which I use spasmodically. Sometimes, I may use it several times a week for maybe 20 - 30 mins at a time, or I may go for a week or two and not use it. Either way, the battery life seemed quite short to me and it ran down when not in use. I was surprised at that as it's a lithium ion battery, which generally hold their charge for months when not in use. This model has wi-fi enabled, so you can browse for books and download them anywhere should you wish to.
I googled 'short battery life between recharging Kindle'. I was surprised to discover that when you close the lid to switch off the Kindle, the wi-fi is still enabled, so it slowly runs the battery down. Given that you only need the wi-fi facility when browsing or downloading books, to conserve battery life it make sense to switch the wi-fi off. You'd think there'd be a tab which says 'wi-fi on/of?' No - it's not as logical as that. To switch the wi-fi off, you have to switch 'airplane mode' on. 'Airplane mode' is for when the pointless announcements are made prior to take-off to say 'all devices must be switched off' (or what - the plane will nose dive into the sea?).
So if you or a member of your family has a wi-fi enabled Kindle and the battery life seems short between the need to recharge, the answer is to switch 'airplane mode' on, and only turn it off (and hence the wi-fi back on), when browsing or downloading books. My Kindle is still almost fully charged after having switched 'Airplane mode' on about a month ago. You'd think they'd alert users to this.
Hope that might help someone.
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
