27-07-2015, 07:32 PM
Here’s an interesting radio. It’s a bit grubby but I am going to see if I can get it working.
Here’s my take on it (please join in with anything to add or correct)
Are there rules re attachments on post's?
- There’s a primary and secondary aerial coil
- 4 valves – the first 2 are rf amplifiers, the 3rd is the detector and the final one an af amplifier stage which can be bypassed if using headphones.
- The 2 rf amp stages use Neutrodyne Condenser’s to keep the valves stable.
- There are 3 Ohm resistors in the LT line – I guess to drop the voltage down to 5 volts from a 6 volt supply for the original der valves
- The grid leak is missing.
- The af coupling transformer is o/c
- Corrosion and flaky joints are all over the place.
- One of the LW coils will not fit.
