25-07-2015, 06:38 PM
I decided to replace some of my halogen security lights with LED types. Because I couldn't find any with an external switch input (4 core cable) I modified a couple by changing the standard 3 core cable with 4 core, the fourth core being connected directly to the LED PSU i.e. the output of the motion detector electronics.
But first, an unmodified was installed about 1 year ago and is working fine. The first of the modified units was installed about 12 weeks ago. This is installed by the kitchen door and is used almost every day, both manually and automatically. The motion detector system has no packed up and the light will only work when manually switched via the fourth core I added. I haven't installed the second modified light yet.
I cannot see how this mod could damage the detector electronics - can anyone explain how? Or is it that I was again(!!) unlucky to be supplied with a defective unit? Either way, the guarantee is now void
Cheers
Brian
.Cheers
Brian
