08-07-2015, 04:45 PM
I have acquired a 650VA transformer that previously lived in a slot arcade machine that was stripped for spares and scrap. As it is potted it was offered for free on another forum due to this lowering the scrap value. The windings are just marked with voltages and nothing else.
The testing it a little bit technical as you have to load up the windings with an entire army of dummy loads and do some ohms law.
The trick is to load each winding while monitoring the voltage until it falls from the open circuit voltage to about half way down to the marked loaded voltage remembering that these will drop a little bit when the more powerful windings are loaded.
In this example I started with the biggest dummy load I had on the 11 volt winding as it read so low with a DMM that there was no chance of getting anything useful from the DC resistance.
I had to load this with 2 ohms to get it down from 12.7V to 11.7V.
This must be something like 110VA.
The 9.5V winding came in at about 2A so that is 19VA.
The 7V winding came in at about 3A so that is 21VA.
The 40 volt winding came in at about 6.25A with a nice toasty dummy load at 250VA.
The 50 volt winding rolled in at 5A with another toasty dummy load at another 250VA.
The totaling based on the size and weight of the transformer is:-
11V 110VA plus 9.5V 19VA plus 7V 21VA
We now have 150VA
Add the two powerful windings at 250VA each and we have a reasonable estimate of the individual ratings of all the windings on this 650VA lump.
We now have 150VA
) if you get the time could you provide a step-by-step guide and provide a description of the testing board with the various loads on it too? It would be most helpful.
