22-06-2015, 03:14 PM
Could I get some advice please?
I have so far assembled a series lamp limiter and a bench variac in advance of carrying out some repairs and restoration of three 1930s AC receivers I possess. I also have an RCD adaptor. I am now having an internal debate whether I should....
1. Just rely on the RCD adaptor.
2. Buy an isolation transformer, ready enclosed.
3. Buy the transformer and construct an enclosure around it.
4. Buy the transformer and construct a variable isolated power supply aka the Heathkit IP-5220.
Cost is an issue. It's unlikely I could afford a ready-enclosed isolation transformer, so would have to wait until a cheap second-hand one came up on eBay. The same goes for a ready-assembled Heathkit i.e. outside of my pocket - even tatty old ones on eBay are too pricey. I could probably afford a transformer on its own and make an enclosure to go around it, and I could also strip down my recently constructed bench variac and build an isolated variable power supply. The question is, how important is it to have an isolation transformer? Some advice would be most welcome.
Thank you
Nick.
Thank you
Nick.
