17-06-2015, 07:50 AM
I have recently been asked to investigste the same problem in two different examples of the above CD Player, which uses a SANYO CD Mechanism. The fault is that, only with some CDs the mechanism 'clicks' when the disc is spinning, both during the initial reading of TOC, and whilst playing, which, in most cases is otherwise OK. Upon investigation what is happening is that the gears which move the Laser PU along the Sled are jumping out of mesh, and a close look at the gear assembly suggests that it's due to wear which allows too much 'play' in the sinndle 'bearing' of the larger white gear. I guess the only cure is to replace either the gear assembly or the complete mechanism, which, IMHO, isn't the best there is, particularly as the Azur is otherwise a good quality 'upmarket' player. However it would be almost impossible to fit any other CD Mechanism in this machine. Is there by any chance a mod. to minmise the chances of the problem being repeated?
