23-05-2015, 06:12 PM
I mentioned in another thread that I’ve got rather a lot of 555 ICs of doubtful provenance, and as I've recently been making a few gadgets which use this versatile little IC, I thought it would be useful to make a simple tester to see if I have any duds. Circuits for such testers - often built on strip-board - abound on internet and I claim no originally for the circuit that I used. I’m not a great fan of strip-board so I designed a little PCB on which to build the tester.
The circuit is basically an astable multivibrator, and when the test button is pressed, if the IC under test is good, the two LEDs will flash alternately.
With the component values chosen, the flash rate is about 3 Hz for each LED. (The frequency of flashing is of no importance, and is determined by the values of R1, R2 and C1). The way that it works is that when the test button is pressed, C1 starts to charge through R1 & R2, and when the voltage rises to two-thirds of the supply voltage the flip-flop internal to the IC will toggle, then pin 7 goes low and C1 starts to discharge. When the voltage across C1 falls to one third the supply voltage, the flip-flop resets and pin 7 goes high, then C1 starts to charge up again and the cycle is repeated. If the IC is good, the two LEDs will continue to flash alternately as long as the test button is pressed.
All the bits were from my spares box - another little 'MFJ' project - 'made from junk'! As is my custom, I made a little comb-jointed oak box in which to house it. The question arose as to how to devise a test socket for the IC. I just soldered a turned-pin socket into the PCB, then added another five pushed into each other, with the uppermost one glued to the front panel with epoxy glue, and the PCB mounted on stand off pillars below the front panel.
Hardly breaking new ground here, but I thought I’d share it should anyone else ever wish to make a 555 tester.
Pics of the the circuit, PCB artwork, component overlay and finished tester are attached. The PCB 6.5 x 5.5 cms.
The 555 is a remarkable little IC, introduced in 1971 by the US firm Signetics, and still in widespread use for such things as timers and oscillators. It’s now made by many companies in the original bipolar form and also in low-power CMOS types ‘7555’. By 2003 it was estimated that 1 billion were made every year.
http://en.wikipedia.org/wiki/555_timer_IC
In terms of longevity, it must rank alongside the 741 op-amp, introduced in 1968, and 2N3055 transistor, which had its 50th birthday in 2014!
Hope that’s of interest to someone.
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
