03-05-2015, 09:16 PM
Cheap, nasty, but serves a function, or at least this one did before the aerial socket sheared off the back, one of the scart plug in types. Pop the plastic to reveal a single board populated both sides with a decent array of chips and bits. Luckily the centre pin had sheared clean leaving something to solder to without having to gut the tuner can onto which the original socket was soldered. I have boxes of single to two way UHF splitters and one was used as a donor to repair, de-soldered the socket and with a bit of the usual swearing and some blu tack managed to get the socket correctly fitted with no grief. Powered up and all ok, tidy little unit with a now extended lifespan.
