04-02-2015, 09:30 AM
Valve....New ?
04-02-2015, 10:20 AM
Ah... I've used Noritake Itron vacuum-fluorescent displays a fair bit over the years. And it's well-known that a VFD can be used as a simple triode. So, I guess this was inevitable..
Looks like the target market is the musical instrument industry, but I'm sure it won't be long before the audio crowd give them a go
04-02-2015, 03:12 PM
Looking at this photo:
...it seems that it is a VFD construction as the anode is fluorescing nicely. Seems quite a small beast too, as much as you can determine the actual size from the image above...
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu
04-02-2015, 03:40 PM
Do you reckon the fluorescing is crucial to the devices operation or designed to enhance the overall visual appeal or a combination of both ? If it was good to 30 Mhz (the valve) I wouldn't mind one of them to mess about with, wonder what the specs are.
04-02-2015, 03:48 PM
(04-02-2015, 03:40 PM)pwdrive Wrote: Do you reckon the fluorescing is crucial to the devices operation or designed to enhance the overall visual appeal or a combination of both ? If it was good to 30 Mhz (the valve) I wouldn't mind one of them to mess about with, wonder what the specs are. The anode fluorescence is due to this really being a VFD, made on a VFD production line, by a company that makes most of the world's VFDs ![]() The anode coating of VFDs is what makes VFDs so useful, but its not essential (just cool). The cathode coating, OTOH, is vital - VFD manufacturers have developed coatings that make the cathodes perform flawlessly for many years - at least 3.5 years (30,000 hours) of continuous running - old purpose-built triodes like the 12AX7, used to need replacing fairly often, with lifespans of less than 10,000 hours. So, to save money, Noritake have used a standard VFD production line to do this - VFD form-factor, VFD internal construction, VFD anodes, grids & cathodes, VFD pin-outs etc. etc. As Mark correctly points out, pretty much any VFD can be used as a triode, some even up to RF frequencies... Sensible move, really...
ʞɔıu
04-02-2015, 04:18 PM
Interesting. I've got some DM160 indicators I'll have to try one as an amplifier.
Keith
04-02-2015, 04:26 PM
(04-02-2015, 04:18 PM)Keithstv Wrote: Interesting. I've got some DM160 indicators I'll have to try one as an amplifier. The DM160 (6977) is pretty much the smallest VFD there is - I love them - several folk on the Google! neonixie-l group have done some fun stuff with them, e.g. .
ʞɔıu
04-02-2015, 08:02 PM
I made a simple multivibrator with a couple of them a year or so ago. Active device and indicator all in one and a low component count.
Keith
04-02-2015, 09:56 PM
(This post was last modified: 04-02-2015, 10:00 PM by Alan Douglas.)
They're small enough to hide in the base of a dead valve. I remember when I first tested one, in a Weston analyzer. I set it up and was watching the meters to be sure it didn't draw too much anode current. The meters were all indicating properly and I glanced up at the valve, and was somewhat startled to see it glowing bright green! Which if course is normal, but I wasn't prepared for it.
As to Noritake, my parents bought a set of their porcelain dinnerware in 1942 when they got married. That was not a popular thing to do just then! I think only one piece has broken since then, and we used it on Sundays or for guests. |
| 2 Guest(s) |
