19-01-2015, 11:14 AM
The switchmode 12v 36 watt (3Amp) PSU supplied with a Habitat 'Graziella' Clamp lamp has failed and replacement PSUs are, it seems, nolonger available. My initial thoughts are to use one of the commonly available 12 volt 3amp psus designed to power/charge Laptops, etc. Is this (a) feasible - I would have to change the connector on the new PSU, as the lamp uses a 2-pin plug/socket rather than the 'standard' DC power type? (b0 is such a PSU likely to be safe and reliable powering a Halogen lamp?
