18-01-2015, 04:28 PM
Haven’t been doing much vintage radio this last few months as I've been busy trying (and mostly failing) to 'de-clutter', so haven’t had anything worth writing about. Really, I should be trying to get on with finishing restoring an Ekco AC77, which has stalled because apart from limited time, I find it difficult to get motivated in winter months even though I have a cosy, heated, and well-insulated workshop.
However, I fancied a little winter project and spotted a basic audio sine wave generator that appealed to me - not that I needed one, but I had most of the bits to hand. It covers two frequency ranges 155Hz – 2,200 Hz & 150Hzx 22 KHz, and two voltage ranges .011V - .24V & .1V – 2.4V. I calibrated the voltage range in RMS rather than peak to peak volts. Had to alter the value of R1 to get it to oscillate as the 28V/40mA stabiliser lamp I used was only 62R (cold) as opposed to the specified one which was 105R. Also, to get the voltage range to be 1/10th of the full voltage I had to use a 470k for R7 as opposed to the specified 47k.
Only a basic thing, but the sine wave looks respectable enough.I found the design here:
http://www.bobsdata.com/audio_sine_wave_...index.html
I fitted the PCB on spacers behind the front panel rather than horizontally, so I could make the box shallower. I drew a front panel when I’d calibrated it and printed it on blue card, encapsulated then covered with a panel of 2mm acrylic.
Yet another 'little wooden box' project - hope I'm not borderline OCD!
Probably of limited interest, but I’ve attached a few pics anyway, including one of the component overlay which I had to work out and draw because though the PCB artwork is on the website link, there was no overlay to show component placement. The only bits I had to buy were the little lamp and the 50k dual liner pot (R5). Both ebay purchases. These rest is simply a rearrangement of bits from my 'spares box'(es) apart from the box itself, which is from an offcut from the end of a mahogany plank.
Hope it’s of interest.
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
