10-08-2014, 07:15 PM
As mentioned in David's post about EPE magazine projects I decided to make a start on this before I headed off of my little road trip.
At this stage I've built the ferrite loop section and it's ready for a housing which will get done in due course. The project calls for seven rods but I bought a set of ten and nine fit in the tube so nine are in use. Also, they are longer than the ones suggested. For the secondary loop the recommended number of turns is 29 to give an inductance of 160uH. Since I'm using more ferrite I had to reduce the number of turns to 26 to get close to 160 - mine reads 170uH. I figure that's close enough.
I've got the base more or less ready for wiring. I'm using components available on hand so it doesn't necessarily look pretty at this stage. Cosmetics will come later if the thing works.
So, at this stage it's ready to have the little circuit board prepared. I got back from my road trip earlier this evening and on checking my mailbox discovered something very wonderful - more about that in the next post.
Cheers, John
Cheers, John
Faced with a similar problem of R.F. switching in the past, I used miniature co-ax relays.
