04-08-2014, 08:14 AM
(This post was last modified: 04-08-2014, 08:19 AM by Old Sparky.)
The WD800JD is an 80GB SATA Drive fitted with a Foxconn keyed connector. Is there any way to connect this to a Presario S7390UK tower which has an ATX PSU with spare connectors for an extra drive, none of which appear to match the Foxconn one?
There are USB & Firewire ports on the tower, if suitable adaptors are available. A supplementary question - is a speciald DVD drive needed to read/write double sided DVD/DVD+ or -R Discs?. These are not recognised by the DVD writer in this PC
