21-04-2014, 08:09 PM
Hi All,
It does appear that my car is on its last legs with a fault that is difficult to diagnose. Its a 2002 Mondeo 2.0L TDCI (130bhp) version. It feel like its dragging its heels when driving and if accelerated hard (especially at speed) the dreaded glow plug light will flash and it loses power (default engine management setting) which clears when switch off. I've had the injectors leak tested and they are fine. I've had it diagnostically checked with a P0251 code 'injection metering control pump A fault'. However, good old Ford, this can relate to about a dozen different things wrong, in particular, a faulty fuel pump which are £500 new (plus fitting). I've replace the fuel filter, cleaned the engine gas recirculation valve and the mass air flow sensors so Im rapidly running out of ideas.
The car is appoaching 150k miles so I'm really thinking that its long had its day. I cant afford to get a new car at the moment so I really stuck and looking for any thoughts other than driving it off a cliff or leaving the keys in it out on the road.
Help!!
Rob
Help!!
Rob
