20-03-2014, 09:11 AM
I am currently repairing a Ferranti 255 AM/FM Mains radio, which, after replacing various waxies and a faulty on/off switch & tone control is basically working. On noticing that there is space inside the chassis to add a couple of 20mm fuseholders, I thought of so doing, fitting a fuse in each lead to the mains transformer primary, possibly using a couple of 80 or 100mA(T) fuses for the purpose. This would give added protection, although I have put a 1A fuse in the mains plug, after changing the original two-wire mains lead for 3M of 3-core. I realise that this detracts from originality, but, as noted above, adds extra protection. The fuseholders would be inside the chassis, fitted with covers, and not accessible without at least removing the cover from the underside of the cabinet. Should I go ahead with this mod?
As an aside, I've often wondered why most continental radios of that era are internally fused, and British sets seldom, if ever were.
