29-07-2013, 07:09 PM
Hi,
I've not touched a vintage radio for quite a while but after clearing out my radio workshop I retained my restored sets and a couple of small sets needing restoration.
Last Saturday night we suffered half a months rainfall in 8 hours. When I visited Aldi this morning there was a huge lake in the middle of the car park but this didn't stop one guy driving through its centre even though the water was up to the cars axles and he was making one heck of a wave; I'd have been amused had he swamped his electrics and had to climb out.
http://www.examiner.co.uk/news/west-york...in-5377092
Anyway it hasn't finished there because we've suffered further downpours all day forcing me indoors. This morning we visited Boundary Mills in Catcliffe and it remained fine until we arrived back home when down came the rain.
After dinner I thought it time to potter around and blow the weather; I collected a small "woody" from the bedroom and carried it into the workshop. This set is an American Emerson which I bought through eBay a few years ago. The set has got very little identity other than the Edison name. The cabinet has suffered some damage in that a vertical wooden bar is missing from the grille panel. I took a number of digital images.
The mains lead is unsafe and no doubt it will run on 110V which isn't a problem because I can hook it up to the Variac when the time comes. The chassis was totally free in the cabinet so simply slid out with a gentle tug; the plastic dial cover was also free it having come unstuck of it's Sellotape fastening; two valves (tubes) were also loose. A couple of "floating" wires could be seen around the internal aerial. It has no back panel. In general though the set appears complete just requiring a lot of TLC?
As usual I drew a rough sketch of the valve positions and then withdrew each valve in turn to try to identify them but most of the markings had long gone; I noted the few numbers and letters I could read on each valve as any information is better than no information? The only identification I could find which meant little to me was "Emerson G-1679 6VD-82A" Under the cabinet was marked CV295 so nothing really to work with.
Armed with the bits of information and pictures I then settled down on the computer in order to identify this set? At first it was slow going; a number of websites had lots of Emerson pictures but I couldn't spot the one I have. Eventually I ended up on an American forum where a guy was restoring a set similar to mine and I now think my set to be a CR261?
http://www.antiqueradios.com/forums/viewtopic.php?f=6&t=187335
Now I was getting somewhere and using this number I finally located a free schematic download.
http://www.nostalgiaair.org/Resources/957/M0004957.htm
I'm indebted to both these sites for the information.
I'm unsure at this point whether this will end up as a full restoration because it all depends on my personal black cloud letting me out to play but at least I've done something other than moan.
My restorations usually start like this; ease gently into them then before I know it they take my life over until completed. The wooden grille is made out of two pieces of solid timber these being machine moulded; the side with the missing piece was found mostly to be loose so was pulled free and this in turn was found to be broken in one area so I used woodworking adhesive to secure it which was a very easy repair.
All I've done is pass away a couple of happy hours tinkering around with an old radio this afternoon so thought I'd pass it on. I'll add more as work progresses.
Does anyone have an easy way of making valve numbers more readable; I've not handled the valves much but I just can't make out the numbers even in strong light? I've got a feeling this will be a pretty set once restored.
Kind regards, Col.
Kind regards, Col.
