I have not seen anything before about this challenging procedure so I have decided to have a go myself.
It tested open circuit on the reformer.
Now it is time to find out what happens.
Right the first thing I did was to clean it up. There was quite a large plug of crystals in the vent hole.
The capacitor had been in a chassis with the terminals facing down so that it had plugged the hole and not collected any significant dust. I pushed it back into the can and added 4 cc of distilled water and allowed it to stand over night for it to soak in. I added some polyeuthrane varnish as I do on good capacitors with tired looking seals. I also plugged the hole with a bung from a computer ink kit.
I have applied power from my reformer and it is taking about 2.5ma at 50 volts. This figure has settled and if other caps of the same type are anything to go by it will now have to sit at this figure for something like 48 hours or so before any further assessment can be made.
Any guesses on on its chances?
