20-04-2013, 08:39 PM
Not really vintage, around 1980s.
Picked this up at the market this morning for 11 Euros, should have been 10 but the guy didn't have enough change. It's in quite good nick, no damage from battery leakage etc.Put 2 AAs for the computer, and connected a 5V supply. Very distorted sound apart from at low levels. AM/FM the same. Opened it up and did a few measurements as you do!!! Was surprised to find only -1.8V on the power line. Checked PSU 5V @400mA. Quick check on the specs and found that the 3 D cells only have a life of 10 Hrs. and that the normal mains supply 4.5V is rated between 9 and 16W consumption so this thing takes >1A +++. Tomorrow I'll go to a local market and try and find a 4.5V/5V 2-3 Amp supply. Has anyone any experience of these?
Hope this is the only problem!!!
Mike
Mike
