18-04-2013, 09:42 PM
I've been asked to repair one of the above which 'won't switch on' The reason for that was soon obvious - mains transformer primary open circuit!
There being no burn marks or any other sign of distress on or around the transformer, plus the fact that the internal primary and secondary fuses are intact, as is the secondary winding, makes me feel that a replacement transformer will get the amp. working again. However because the TX is likely to be expensive, I decided to 'cold' check the main amplifier PCB. First thing
I discovered was that, unlike in the majority of amplifiers the speaker common negative terminals are not earthed. Checking the components and PC Tracks with a meter revealed no obvious problems, nor is there any sign of leaky capacitors, dry joints, etc. The output transistors(?) are a type I've not encountered before. Each has 5 terminals. They are SAP15s, which, from what I've seen on the 'net, can be troublesome, and may have been superseded by other devices. Should I obtain replacements for these as a
precaution? (That is, assuming the amp's owner wants to fork out the price of a new mains transformer!)
