13-09-2012, 01:21 PM
Hi All,
Not sure if this should be in domestics or auto but as its used for cleaning my car I've put it here.
I've a problem with this washer that I can't seem to find any solution to, so can anyone help. The washer is working electrically when switched on as I can hear the pump operating. However, the water pressure is no different to that of the water pressure from the tap so something is definitely not right
Thanks
Rob
.Thanks
Rob
