05-06-2012, 01:46 PM
You may be interested to see my latest video upload on U Tube:
http://www.youtube.com/watch?v=ff6DlppOMpc
It shows the replacement of a missing section of loudspeaker grille on the cabinet of a 1946 Major Maestro. The set itself was the subject of an article in Radio Bygones quite a few years ago now.
Tony
Tony
I used to use Milliput an awful lot in my model-making. One method we used to use which is to make sheets from it the same as making pastry. You need something you can use as rolling pin and then sprinkle talc on the flattened ball of Milliput. Obviously the talc stops the rolling pin from sticking. It's quite easy to create really very thin sheets indeed, the results of which would be used to make webbing and shoulder straps for scale military figures.
