18-05-2012, 07:56 PM
Hi Folks, your thoughts on this one please.
I have a 2year old mondeo with electric windows, approx 4 times a year, with the key out and the car locked, all the windows will wind down (usually overnight). It happened twice on consecutive days recently.
I believe it may be due to Rf energy or some EMC problem, but we live in a reasonably quiet area electrically. Examination of the limited schematics in a Haynes manual reveals that while the window control circuits are fed through "ignition on only" circuits the actual motors are not. There is also the dreaded CAN bus that is permanantly active.
A Google reveals many cases of this fault, Ford having a deaf ear, or much speculation on the cause but no solutions.
My thoughts are to fit a latching switch in each door to break the motor circuit. The alternative of breaking the motor drive circuit with an ignition controlled relay at the fuse box may raise other issues, as the module that is fed from this circuit has central locking and other components associated with it.
Over to you, Ed
Over to you, Ed
