05-05-2012, 04:47 PM
I've finally started to have a look at my latest DAC90.
The wiring is in a bit of a state
I took the chassis out and noticed that the voltage selector was on 210V. The dropper seemed OK so I put that up to 250V. I then changed the AF coupler and, after checking none of the balding wires were touching, gave it some juice. Nothing seemed to be happening but I then saw faint glows through the muck on the valves. I also saw the the lamp limiter was getting un-healthily bright. I then remembered that I hadn't snipped the filter. This looked like it had already spewed it's guts at some stage and after chopping its wire it played quite happily.
I tested the grid on the UL41 and found about quarter of a volt. I've hitherto used my DMM for that but the battery is flat. I didn't use my valve voltmeter as I wasn't sure as to the safety of using this on a live chassis. It was interesting to note how connecting the AVO caused a drop in volume and my little 2000 ohm/volt one an even greater one.
Call it silly anthropomorphism if you like (but remember I'm a Moderator with the power to ban people
) but in my experience Bush sets just WANT to work whereas quite a few others seem to be happy in their slumbers and will fight to continue their retirement.
The extra sockets on the back weren't connected to anything. The speaker leads have been extended but it must have been done some time ago as they've had time to go crispy.
The main interest in this one will be repairing the case and I was pleased to find that it hadn't been glued but stuck up with parcel tape so doing a better job will be more straight-forward.
- Joe
) but in my experience Bush sets just WANT to work whereas quite a few others seem to be happy in their slumbers and will fight to continue their retirement.The extra sockets on the back weren't connected to anything. The speaker leads have been extended but it must have been done some time ago as they've had time to go crispy.
- Joe
