14-04-2012, 06:01 PM
Last year some time I got a Roberts R200 which didn't work.
I changed a few caps but couldn't get it going. I had another look at it a couple of days ago.
I found another electrolytic which was o/c but for all that a 1kc/s signal injected into the volume control would come out of the speaker it wouldn't any further back.
This morning, I started poking about with a diode and amplifier but couldn't get any signals anywhere.
Chiefly because I couldn't think of anything else I took TR1 off and tested it. I was sure I'd tested all three AF117s when I got it and the soldering appeared to have previously been deflowered. Whatever, there was a short between the screen and collector and after bopping that it tested with an hFE of 196 and when it was put back in the set that worked.
I also checked the IF alignment which was a bit out and a quick twiddle improved things even more.
Cosmetically it's had a clean up and a new piece of leather fitted to the outside of the handle.
It's an achievement for me as I think it's the first transistor set I've managed to repair that's needed more doing than bad connections or something equally obvious sorting out.
This is as well as I've just bought a Hacker Sovereign - more on which when I get it.
- Joe
- Joe
