05-01-2012, 09:58 PM
(This post was last modified: 05-01-2012, 09:59 PM by Ed_Dinning.)
Hi Gents, I just thought I'd get some opinions from forum members.
I have a 30 year old Glo-worm gas boiler that works very well and is fitted to a fully pumped and controlled system with zone valves.
People are telling me to get a modern condensing boiler, but the need to totally change the system and remove the copper cylinder would give a long pay back period.
I also intend to fit a solar hot water collector of my design and feed it into the tank on a new coil as a feedwater heater. This I could not do if I remove the cylinder.
The idea is to insulate the free standing boiler to reduce heat losses from its water jacket by means of a modern insulating blanket that is a similar material to shuttle tiles. This will fit inside the boiler sheet metal casing and be clipped against the outside of the boiler, obviously leaving gaps where there are air intakes, flues and other combustion access. This should considerably reduce losses from the boiler shell.
Your thoughts Gents?
Ed
[font=Arial][size=medium]
Ed
And the hot water cylinder in the airing cupboard has gone too, so bigger cupboard (but I am forbidden to put 'radio junk' in there!
