17-12-2011, 11:22 AM
Hi All,
I've just received my second set of vintage cone lights (12 bulbs) that are working well. However I need to extend the cable as its far too short and the plug will be halfway up our tree once these are put on it for decoration.
I ma aware that the most sensible option is an extension cable but this just isnt practicable.
I beleive I have two options either to use a cable connector or to solder and use heat shrink/insulation tape. Is the cable connector the best option.
Doh!!:s
Rob
Doh!!:s
Rob
