I think most of us have been in the situation where we have a mains transformer of the type suitable for a valve radio and need to know "what it's good for" - in terms of voltage and current - for that repair or design job that is being undertaken. If you're lucky, you'll know some of the essential data - in particular, what the HT winding is capable of in terms of voltage and current - usually on account of information stated on the transformer. But when that isn't the case, what do you do? 'Suck it and see'? Rely on 'calibrated eye-sight'? My typical resort is to successively connect an assortment of different power resistors on the HT winding and monitor the resultant current and voltage. But easy though this may be to do, it has its drawbacks. On account of the inconvenience of needing a large number of power resistors of various values (which will get hot), there is also the risk of damage to the test equipment in use and the transformer under test from accidental short-circuits. And the real risk of receiving a very nasty HV shock is ever present! :omg:
Over the years I have accumulated a large number of such transformers and it is a great convenience to build a database catalogue of their significant specs. to help me rapidly locate a suitable transformer when needed. Faced with the prospect of using the method outlined above, I decided it was time to build a test unit to make this job a lot easier, now & in the future. Such a unit also has a use for testing a suspect mains transformer when said item is fitted in a radio which is undergoing repair.
This is my write-up of what I ended up with. It's certainly not going to win a constructor's competition,
but it did cost me very little in terms of specific expense: in particular, only the meter. Everything else came from the proverbial 'junk box'. The reason I am producing this Post is simply to show that such a unit can be designed & assembled by anyone for little cost: the design can be simplified or expanded according to one's needs and resources.
Basic usage.
The whole of the HT winding of the transformer-under-test is connected to the unit's two input terminals: so a 350v - 0 - 350v transformer has no connections to the centre-tap. The mains voltage is applied to the transformer primary and a variable stepped resistive load inside the unit is internally connected across this winding. The resultant a.c. voltage and corresponding a.c. current are monitored on a meter as the internal load is varied. The meter is front-panel switched between voltage and current.
The unit is designed for a maximum input voltage of 1,000v r.m.s. and a max. input current of 100 mA continuous, 200 mA for 'soak' testing. The unit contains its own 230v.a.c. fan.
Photographs are below.
To prevent this Post from becoming a total monologue, I'll stop now. Further remarks may be added later, depending upon this Post's response (if any). :D
[attachment=3479][attachment=3480][attachment=3481][attachment=3482][attachment=3483]
Al. / Dec. 5, 2011 //
but it did cost me very little in terms of specific expense: in particular, only the meter. Everything else came from the proverbial 'junk box'. The reason I am producing this Post is simply to show that such a unit can be designed & assembled by anyone for little cost: the design can be simplified or expanded according to one's needs and resources.Basic usage.
