29-11-2011, 05:15 PM
Hi,
Whilst visiting our friends Steve and Julie on Sunday Julie asked if I could possibly turn four wooden chaise longue legs for her. Julie is into crafts and upholstery and likes to make furniture. Of course I would be happy to help out so today I was surgically removed from the computer and went into the black hole (garage).
Julie was vague about the dimensions but said she would like traditional style legs rather than modern and it didn’t matter what timber I used.
I had a look round my stock and pulled out a 34” length of 2.75” square seasoned oak which I’ve had for over ten years. A few inches longer would have been better but I cut four 8.375” blanks from it and marked each of the ends for centre. I pricked a hole on centre; then as I don’t have the luxury of a live tailstock centre I used a screwdriver to add a bit of paste wax which I find is a brilliant lubricant once the blank is mounted on the ring centre. The four prong drive was located with a hammer then the blank mounted between centers.
I had moved the compressor and other items away from beneath the lathe and pulled the Startrite combination machine near to use as a bench for the woodturning kit. The weather is dire as usual and two feet away from my elbow the wind and torrential rain were doing their best to push the garage doors in. I really need to learn how to work in a black hole as I’m sure it would be useful. The workshop strip lights are in the wrong place for the lathe so I rigged up a temporary 60W lamp casting very nice shadows over the work.
I had made a rough dimensioned sketch of the leg design so transferred the dimensions onto a “story stick”. I always do this when faced with repetition work as I only need to measure once eliminating making silly mistakes; at least it usually does assuming I can see what I’m doing.
With the tool rest adjusted and everything checked for security also ensuring the blank turned without fouling I was soon sending the shavings flying using a heavy spindle gouge. Once the blank had been reduced to a cylinder dimensions lines were added using the story stick to mark from; just a touch with the pencil then with the lathe in motion the mark was extended around the cylinder and work progressed nicely. Whilst turning this first leg I made up the various diameters as I went along working on what looked right.
It was very difficult given that I was working in shadows to watch the cut as the tool was applied; the corners are a blur at speed and catch novices out but I wanted to complete these legs today as the forecast is for colder weather so I battled on. I roughed down with the gouge but used the skew chisel for the finishing cuts on the flat sections which give a shear cut saving a lot of sanding. Calipers were used to transfer the various diameters from the first leg. After sanding to 240 grit I used a short length of dowel to burnish the surface then added the wire burnt rings.
Had it been a nice day I would have enjoyed doing this job without having to rush. The legs are not perfect and certainly not up to the galley standard which my chum David (Yorkie) produces but given the conditions I was working in I’m sure Julie will be delighted to receive them with my compliments.
Kind regards, Col.
Kind regards, Col.
