I've listed this under 'home-brew' albeit the project is based upon a little Velleman kit, which I boxed up and made a couple of probes for, so I guess it was a team effort between me and Velleman! I made if for a chum as a 'thank-you' and thought that a few others might like to know about this neat little kit, and a few notes on signal tracing/injecting.
We all have our own approach as to how we go about fault tracing is non-working radios, and my approach ever since my teens more than fifty years ago has been to first of all look for obvious faults such as loose connections, broken wires, do some voltage checks, continuity tests on speakers, OPTs etc, then to use a signal tracer/injector approach to test the audio stage to see if the fault lies there or in the earlier stages. (As an aside, from long experience of dead audio stages in transistor radios, the culprit is often an open circuit earphone socket. It's only supposed to silence the speaker when the earphone is plugged in, but the spring contacts weaken over time and often go open circuit even with the earphone plug removed).
By injecting an AF signal of about 1kHz (actual frequency unimportant) at the slider of the volume control, if there's a loud tone from the speaker, that shows that at least the audio stage is working. But suppose that the AF stage isnt working - what then? If the RF/IF stages are working, a probe from a signal tracer (which is basically, just a small amplifier), placed on the slider of the volume control will show whether those stages are working. The tracer basically substitutes for the AF amp, so if the RF/IF stages are working, tunable signals should be heared on the speaker of the tracer.
But what if there are no signals at the volume control slider?
By applying an RF probe (a diode detector attached to the tracer input) and working towards the front end of the set, the faulty stage can be found. EG, if there are no signals getting to the detector valve (or diode in a transistor radio) the second IF stage may be faulty, but if a signal from the injector is squirted into the grid of the IF valve, and the tracer probe applied to the detector, and a loud tone is heard, that suggests that the second IF stage is probably working and the fault lies closer to the front end of the radio. If the tracer probe is applied to the grid of the first IF valve and tunable signals are heard, that proves that the mixer/oscillator (frequency changer) is working. However, if no signals are heard, that stage is faulty. If the signal injector probe is applied to the grid of the first IF valve (or base of the first IF transistor in a transistor radio) and the tracer probe is placed on the slider of the voume contorl, and a loud tone is heard, that's a good inidication that the IF stages are working, thus confirming that the fault lies in the front end. If could be the valve not oscillating due to the valve itesle or associated curcuitry, open circuit coils, faulty wavechange switch connections etc.
If you place the RF probe at the grid of the hexode section of the frequency changer valve, you are basically turning the signal tracer into the equivalent of a crystal set by connecting the probe just to the tuned cirrcuits of the radio, and if you don't hear any signals, there must be an open circuit in the coils, such as a frame aerial, aerial coils, ferrite rod or whatever. In fact if you just connect the RF probe to an aerial and earth with no radio attached to it at all, you'll hear several stations all on top of one another!
It may take a little time to get the hang of adopting this technique to anyone not already familiar with it, but once adopted, it saves hours of headscratching peering into a rats nest of wires and components wondering just where that elusiver fault might (or might not!) be.
The Velleman Kit K7000 consists of a PCB and all the board mounted components including the volume controls for the tracer and injector, both of which are mounted directly on the PCB. In addition, you need a small speaker, switch, LED (if desired) sockets, a box of some sort of project box in which to house it. I made a little comb-jointed oak box as I do for most of my litle test gear items, and as a front panel I used a scrap piece of PCB sprayed white.
You'll need to make a couple of probes. For signal injecting and AF signal tracing I just used an empty marker pen, with a probe tip made from brass rod sharpened to a point, and a 0.1 630V cap inside simply as a precaution to prevent damage to the tracer if the tip was placed on a high voltage point in a set. It's kinder to apply the tracer probe to the grid of a valve after the DC blocking capacitor than at the anode of the previous stage, but at least the cap in the probe will protect the tracer. For the RF probe, I used a little plastic pill container and made a simple diode detector on veroboard, (again with a 0.1 630V blocking cap to protect the probe and tracer from high voltage), but the few components could jut as well have been hard-wired to each other 'ugly style'.
I've attached the simple circuits of these two probes - the AF probe is used both for AF signal tracing and injecting - the RF probe is used only dffor signal tracing in the RF/IF stages prior to the detector.
The K700 Kit info and contraction manual can be found here:
http://www.vellemanprojects.eu/downloads..._k7000.pdf
You can buy the kit from ESR Electronics at this link:
http://www.esr.co.uk/velleman/products/index_kit.htm
The attched pics show the one that I made. (The speaker was glued on with a hot melt glue gun).
Hope that's of interest and these wordy notes make sense!
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
