08-07-2011, 08:56 PM
Having recently blown the dust off my antex 25w soldering iron to change 'that' cap and mains lead on my Fenman, I found it seemed slow to work on the larger joints. I guess it is more suited to PCB work with discrete and surface mount components.
I assume I shall need a larger iron to work on our old valve sets, what would be a suitable size?
I bought lead solder, I don't think anything else was available when I last soldered anything, are there any problems with lead free solder? Does it mix with the solder already in our old equipment?
Any thoughts appreciated.
Regards
Andrew
Regards
Andrew
