03-07-2011, 04:22 PM
Hi,
Isn't it strange how one job always causes another. I wanted to move a quantity of stone from the rear to the front of the bungalow this afternoon so thought I would use the wheelbarrow.
The wheelbarrow has been sitting in the shed for a number of years and I knew the tyre was flat; this barrow has been little used. I pulled it out of the shed and what a surprise the wheel had broken!! So much for modern manufacturing; I'm just glad it didn't break as I was inflating the tyre.
Being tight and couldn't be bothered trying to obtain another wheel I had a look around to see what I had to hand and found a few small rubber tyred castors of the swivelling kind.
I selected two off cuts of 2" square mild steel tubing and didn't even need to cut these to length. A bit of welding and hole drilling and the barrow is working once again and won't suffer from any more flat tyres in future. The swivelling part was also welded. Not the prettiest job but functional and above all it cost nothing.
An unusual but interesting project; I had considered making a wooden wheel.
Kind regards, Col.
[attachment=2347][attachment=2348]
Kind regards, Col.
