11-07-2023, 02:10 PM
I have acquired this old home made Wireless World Oscilloscope, built from a design published in 1964. There are a few minor faults on it bit unfortunately the tube has a big fault - it is really dim and will not focus. In desperation to find the cause of the problem I replaced the 5 inch VCR97 with a pin compatible 3 inch tube and it seems to work. There is no uMetal screen on the replacement - the pattern shown is is all due to the magnetic field from the various transformers, the amplifiers are disabled by having their valves removed..
I don't know what has happened to the tube, maybee the focus connections is disconnected inside. The base is loose on the neck so perhaps a wire has broken although I cant see it. Could it be gassy? there is still a dim spot about 2cm across. There is almost 2kV eht, I cant turn it up any more.
I used to have a few old 5 inch CRTs, but they all got lost in various house moves and over drastic clear outs, now I dont have one, shame. I'd like to restore it to working condition. The design is interesting in that the Y amplifier and timebase are plug-in modules. It reminds me of the 'scopes I had - one of which I made myself from an old radar display.
Another unusual feature for a home-made design is the RF-EHT unit, in all there are approx 16 valves, three transformers, and some semiconductor rectifier and other diodes. I received the schematic with most of the changes the constructor made from the published design. It must have took some building, he said it took months with all the metal folding involved.
