02-10-2022, 07:21 PM
So, I was given this with a pair of speakers I bought as a "take this as well". Obviously home made but is it to a recognised design?. It has 4 bdy56 power transistors, a board with 3 hbf4016ae's and a lm381m ic, apre-amp?. A board withlp1185 & 1186 modules, ca1310e ic, so a stereo decoder?. The front panel has a 'pot' with led and 4 leds with touch sensitive pads marked tune, 2, 3, 4. (radio 2,3 & 4 with fine tuning maybe?). Three more pads with pu, radio & tape. Balance & vol' control, power on/off. Rear panel has 2 din type speaker outlets with toggle switch, 2 din inputs of different configuration, a coax and single banana type socket which goes to one of the power amp boards, it's green so an earth?. 2 of the boards are covered in links so home made. The 2 power boards are marked 'lindsley hood 75w'. Off the rectifier are 2 fuse holders minus fuses. What say I connect a couple of sacrificial speakers, an mp3 for input, put in a couple of low (very low) rated fuses, check my life insurance and plug it in. What could go wrong!.
