04-01-2022, 12:44 PM
I agree that "logical" fault-finding and test is the only way, faffing around with replacing caps will get you nowhere and you'll learn nothing, sorry to be blunt but it's really the only way.
Once the set up is tested and you have a result and diagnoses you'll know where to go, whether it's the amp, speakers, connections etc or the Acoustics of the room you'll know what to do.
If it turns out the be amplifier related don't please do blanket substitutions, feed the amp with a suitable Sinewave and then trace where it's changing in level, a doddle on a stereo amp as you have two channels to do comparisons with and you'll learn a lot, bunging in Electrolytic caps also might not cure the fault and is expensive and pointless.
