25-10-2021, 07:59 PM
Hi Mike
I tried plumbers PTFE tape years ago. But the result was not good.
One of the problems was that the tape was soft and the ECW tended to cut through it or bury its self into it reducing the thickness of the tape doing the insulating.
Again years ago. Before the internet and before I had access to proper tapes. I did some tests on the breakdown voltage of PCB tapes. There was a huge difference from brand to brand.
I found one that was good and used it on a pulsed EHT transformer to insulate between layers. The transformer worked 24/7 for years before eventual the PVC tape broke down. At the point of the breakdown there was about 3.5KV across 4 or 5 layers of tape. I think part of the cause of the breakdown was the ECW over time sank into the tape reducing the thickness of tape between layers.
Frank
Frank
