01-09-2021, 05:16 PM
A nice idea with the valve bases Amie. I have seen it done before but a tidy solution.
One option that I have seen mentioned for AGC but I have not seen a working example of is to use a 1j37b two x g1 valve and use one of the grids for gain control. I have done a little bit of testing and it does seem a reasonable possibility although I have only tried it at low frequencies / DC as yet. I don't fully understand the process but it seems more like the control of gain on one grid is more like a tap on a fixed bias than shifting the bias on the signal grid which is the usual method (giving distortion / clipping near cutoff). Please let me know if I have that wrong. My take is that the input range may well be a problem with any of them.
At least with initial work I plan to use agc on my RF stage only and make it switchable with optional manual gain. With a more traditional RF valve I do feel I can avoid an overload of issues to check on. It will mean lots of thinking about how to handle the agc control though. Your delayed amplified AGC sounds about right Kalee. I'm not sure if I am being ridiculous or not but I even had thoughts of using an op amp in the AGC line to give ready control of voltage levels (some of my thinking does get 'over the top' at times). Further down the line ideas may well present themselves for effective use of rod pentodes, but a good stable mixer / IF / audio setup will help to categorise problem areas. This guides me to avoid total rod pentodes at first and splitting stages into modules, risking poor efficiency, so that I can isolate problem areas. Something I have learnt over the years is that easy maintenance / faultfinding is a must, especially if the paperwork is not perfect, as, say, in two years time when something fails a mass of electronics seems just like a mass of electronics and not readily fixable.
Another point I have seen little information on though is noise performance. My suspicion is that rod tubes should be fairly quiet as they should have far less / no problems with partition noise (as the grids are not grids and not in the electron beam). There may be advantages in terms of lower voltages too? This is one reason why I have built a 1j37b mixer (another being that my pantry transmitter uses a very simular modulator). Although it is obviously different I am reminded of a beam deflection mixer which is apparently quiet. Although I have bought a couple of noise diodes, some while ago, I have not got round to assembling a test setup yet, never mind how to use one to determine mixer noise.
It is interesting how we setup these ideas to improve reception Amie. I have my two aerials, one loop and one large ferrite rod, working together. I found this by accident as the inter-react. For a station like Caroline they are easy to use though as they are readily tuned and aligned but they would be more fiddly for DX work.
Tracy
Tracy
