29-08-2021, 07:58 PM
Perhaps some will remember I made a two valve TRF using 1J42A rod pentodes. The radio worked amazingly but then I popped one of the filaments and when I replaced it the performance could never be replicated. Its bugged me for a year or more.
So I decided to have another go. These low voltage 1J42A's are like hens teeth and I've never seen any more than the 10 I bought a good few years ago.
I have now three valves in circuit and although it works very well it is not as good as the original that was literally ear splitting.
I did substitute the output with a 1J18B and it's ear splitting, I'd think if all the valves were the higher voltage versions the radio would be really excellent. Reaction is very smooth with one setting covering half of the medium wave band. Sensitivity tails off though at lower frequencies.
I include the diagram. The audio stages share a common screen feed and decoupling, I've purposely not used potential dividers so I don't need to add an HT switch, valve voltages are low and initially I had 2v on the RF amp anode with good results, it's now at 4v with a slightly higher gain, lowering the anode load resistor although giving more HT its negated by damping the RF, a choke works but the reaction is harder to get working smoothly I may try a choke in series with a lower value resitor, a bit of trial and error.
Overall pleased with the result.
I like the speed of construction with that method you've used, youve done a neat job too. Plus the old school Phenolic front panel love it!... I've done a few circuits with the Ruskies now, amazing for their size, I'll have to get some circuits drawn up of the little audio amps I've been playing with, particularly pleased with the push pull class A self split 3 valve using a pair of 1j29b as output.
