15-01-2021, 02:09 PM
I read about the Coketron on the TekScopes group on groups.io. The original is by Peter Keller who worked at Tek many years ago. There's a picture of typical Coketron here: https://www.sm5cbw.se/tubes/htm/coketron.htm
Quote:I guess it is time for the real story of the Coketron to be exposed.
The Coketron was originally developed for the cost reduction of the 545-B
with the new 545-C [ 545-C nomenclature - C for "Cokescope" ].
Advantages of the "Cokescope" included:
1. Lower material cost - Coke bottles only cost a few cents vs. several
dollars for CRT bulbs.
2. Independence from on-time supply issues caused by labor strikes at
Lancaster Glass and periodic flooding of the Corning Glass plant by the
nearby Chemung River. Coke bottles were always available anywhere.
3. Added employee benefits at Tek - the Coke bottles had to be emptied
by the bulb prep group before use.
The disadvantages that caused the program to be cancelled were pattern
distortions and how-the-heck do you paint the accelerator helix on the
double reentrant curve of the bottle? Also, the glass 2-liter Coke bottles
necessary to better fill the big round hole in the 545-C front panel were
not yet perfected. 2-liter plastic Coke bottles were tried but they tended
to sag into strange shapes at bake-out.
Seriously though, Tom Lee was closest.
Two Coketrons were made several years apart in the Engineering Tube Lab just
to show that it could be done. The first used a T3100 or T3160 gun and
worked surprisingly well. I can remember it displaying the crosshatch
pattern generated by the CRT engineering B2 test sets. Unfortunately, the
tube later rolled off a bench and failed the impromptu drop test. I believe
it was during a lab move.
The second tube used a T2110 gun and suffered a cracked bulb due to thermal
coefficient mismatch of the glasses during processing. This was repaired and
became the tube pictured in my book. This one did not have phosphor on the
screen but glass fluorescence would usually suffice to display a trace. Both
tubes did have complete electron guns with deflection plates. I can't recall
the second tube actually being operated but excessive gas levels due to
little or no bake-out because of the TC mismatch might have been the reason.
I remember it was mainly constructed for photos since we had none of the
first tube.
There you have the rest of the stories. Take your pick!
All of this was 30+ years ago so memories are a little fuzzy.
Peter Keller
