04-08-2020, 10:25 PM
Direct sunlight is indeed a problem as can sunlight going through a glass of water, or a vase as this can act as a magnifying glass and concentrate a beam of light onto the screen and pop goes the tube.
Normal running shouldn't be an issue, mazda tubes with 12.6v 300ma heaters get mighty hot, the heater itself dissipating 3.78w. Add in the cathode current heat from scan coils etc and yes they do get hot, the glass though is soft so should expand and contract without cracking.
